highlight component in Allegro PCB ?
Antonios
Banned
Cairo
highlight component
how to hight lighit component and it's connected net in Allegro
centiago
Full Member level 3
Lions Den
highlight net allegro
to Highlight click the highlight button, choose component in display & slect compnent. Alt choose component by list, expand it & typr refrence designator.
Refering to your other post. To highlight nets . in above process, put all off & select net type net name or choose it from the list.
To dehighlight select dehighlight & choose the respective field & say ok.
neena
Member level 4
pluto
highlighting a pin in allegro
choose higlight button or display-->higlight
choose Find Tab,if u want to select the nets turn off all except nets
then select the net that u want to highlight
for dehighlighting
select dehighlight button or display-->dehiglight
choose option tab and select nets
then click the net in th layout that u want to select
rghrob
Junior Member level 2
allegro highlight
Here's another way:
If you have CIS schematic and the Allegro opened simultaneously: You can click on the CIS schematic net/part and it will automatically focus/highlight for you in Allegro.
abhi002
Full Member level 5
searching
allegro create sub-drawing
Hello,
What are the import/export option available with allegro?
neena
Member level 4
pluto
export package pin delay allegro
Import option available with allegro are
1. Logic 2.Artwork 3.IPF
4.Stream 5.DXF 6.IDF
7.IFF 8.Router 9.PADS
10.PCAD 11.Sub Drawing 12.Techfile
13.Placements 14.Annotations 15.Pin delay
Export option available with allegro are
1. Logic 2.Netlist w/ Properties 3.IPF
4.DXF 5.IDF 6.Router
7.Sub Drawing 8.Techfile 9.Libraries 10.Placements
11. Annotations 12.Intercomm 13.IPC 356
14.ODB++ inside 15.Save Design to 15.0.. 16.Save Design to 15.2..
17.Pin delay
Regards
Neena
taymoor2000
Member level 2
allegro pin delay
from display\highlight
fron find window select Net
then select any point in design
