AnEngineer7
Newbie level 1
Hey all,
I hope this post finds you well.
I want to design a high voltage pulse generator circuit that is able to output voltage as high as 400v in a time duration ranging from 20 nanoseconds to 20 microseconds when a push button is pressed. I also need to be able to adjust the time and the output voltage. I've researched for awhile now and most of the components that i required aren't available in my country :')
So please help me design this circuit if im going to use a power MOSFET PF7N60C, can you guys tell me what capacitors should i use or if im going to need inductors and create a DC boost chopper - like circuit and how can i adjust the time and voltage?
The only idea i have about adjusting the output time is an arduino signal to the mosfet's gate. If there's a better way please tell me.
Thank you :')
Thank you :')
