High Voltage Probe
TXRX
Full Member level 2
Full Member level 2
I need to measure a pulse of high voltage of 1300V at width of 100nSec on a scope.
Do you have recommendation for high voltage probe ?
Thanks,
If you google "DIY HV Probe" or "DIY high voltage probe" a number of
possibilities.
Your 100 nsec requires a significantly higher BW if you are trying to get timing info.
Above some possibilities.
Some insight into selection -
Regards, Dana.
Probably have to start with some idea of acceptable tip loading - 1M is over a milliamp, can you go lower-Z in pursuit of BW or will DC accuracy force you to accept worse?
Might think about a capacitor divider and a regular 1M/7pF probe to get better edges but still Heisenberg wants you to look at the effects of trying to measure, on what's being measured.
If the measurement is single ended, I would start the search with off-the-shelf 100:1 probes, e.g. PMK PHV1000, 50 MOhm/7.5 pF input impedance and up to 4 kV peak voltage rating. I don't hear a preference for DIY in the original post.
