2us is a very short time for a spark. Are you sure you can ionize gas within this short piece of time?
The gas is for example very clear agron and for ionization just a shorter event., for example beta particle.
let physics aside, aplicacion request is
Electric ignition with voltage min 6000V (gap about 2-5mm)
length of spark about 2micro second with a repetition ratio of 50-100Hz.
That's all I know.
I got it on the table. Black box, in epoxy resin.
On oni side is inut for DC 24V and driving TTL input on second side is HV output .
for short shot on drivimg TTL this generate on output 6500V with pulse duration about 2,4us
if drive input is active generate about 62 shot every second in this mode is output voltage lower and the time between shoots and the length of the shot floats +- 30%.
My first idea is 2MHz high voltage generator, but her is problém with realizing induktance
In short I just do not know how to do it
