abuhafss
Full Member level 2
- Joined
- Aug 8, 2010
- Messages
- 142
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 2,383
Hi
Here is a schematic of a DC-CDI.
The upper part is pulse-shaping module and the lower part is High Voltage converter, red box. The transformer is a tiny EE core with 22 turns of 0.3mm wire in primary and 140 turns+30 turns of 0.14mm in secondary.
The pin#1 of the comparator IC is issuing final shaped pulse, which is fed to the gate of the SCR. This shaped pulse is also sent to the lower part via 1N4007 to pause the oscillation while the HV capacitor is being discharged.
I simply need help to understand the working of the lower part of the circuit, especially the network connected to 30T secondary.
