high speed signals in PCB
senmeis
Full Member level 3
is it correct that high speed signals propagate in PCB as waves in dielectric materials such as FR4 according to microstrip principle?
Senmeis
it basically depends on your frequencies as well as on the length of your traces.
As a rule of thumb, if the trace length is shorter than a tenth of the wavelengt of the highest frequencies (\[{l}_{trace,max}\] < \[\frac{{\lambda}_{max}}{10}\]), wave propagation effects are negligible.
BR
For time domain guys, we need to care about controlled impedance when the line propagation delay becomes significant compared to pulse rise/fall time.
@stenzer
does the measure of 1/10 wavelength mean only 1/10 wavelength or does it mean integer number of wavelengths + 1/10 wavelength?
The PCB structures have to be analysed as planar transmission lines, line type according to the geometry e.g. micro strip, embedded stripline, coplanar strips with or w/o ground, coplanar waveguide.
@wwfeldman
It means smaller than a tenth. So if the length of your trace is shorter than \[\frac{\lambda}{ 10}\] (e.g. \[{l}_{trace,max}\] = \[\frac{\lambda}{12.3456789}\]) wave propagation effects can be neglected, see The RF and Microwave Handbook.
BR
