High side transistor driver
epp
Full Member level 5
high side transistor
How can I make simple and fast high side IGBT driver which works with 25A, 400V and switching frequencu 70 kHz? I need it for simulation in pspice schematics.
Thanks.
highside transistor
Look there, maybe some ideas :
h**p://www.ixys.com/tmosign1.pdf
h**p://www.ixys.com/NEW_WEB_PSpice_02A04/DRIVER_TYPE/Mosfet_Igbt_Driver.asp
* = t
    epp
pspice high side driver
High side driver needs galvanic isolation from the main driving circuit.
A good idea both for Spice modeling & real schematics is to use a separating transformer (ferrite core).
Another variant is to use one of the special high-side driver ICs, both datasheets, apps examples & Spice models can be found, for instance, at www.irf.com
    epp
spice high-side driver
the simplest way is to use a pulse transformer....
this document describes how to drive MOSFETs.
also you can use same circuits for IGBTs...
Design And Application Guide for High Speed MOSFET Gate Drive Circuits
By Laszlo Balogh
    epp
tlp250 spice
You may consider to use optocoupler + driver
4n35 olb
Is optocouple enough fast for fast switching .I've made a simple driver for MOSFET use 4N35 and IRF540 but the driver wave form isn't a square pulse --->MOSFET rather hot
tlp250 pspice
4N35 has rising and falling time in the range of 2µs.
It's main use is: digital logic inputs, microprocessor inputs, ...etc.
For driving MOSFETs there are special options called Gate Drive Optoisolators, example TLP250/1 from Toshiba..
transistor high side driver
May be you can consider to use iCoupler (tr=tf=3ns) from Analog Devices.
laszlo balogh high side driver
Today I've gone out to find TLP250/251 but all the shops where I asked ,haven't got this
I find IR2103 but it isn't opto and expensive more than 4N35 (about 8 times) .Could you list here list of driver MOSFET type optocoupler for me .
I find 6N135 can it use as TLP250/251
Added after 28 minutes:
If I want request sample ,where company can shipping for me directly .I'm living in Vietnam. Beside Toshiba ,is there any company producing this
tlp250 example circuit
Does anyone have some model (*slb, *.olb library) of these drivers?
