hughmanoid
Junior Member level 1
- Joined
- Feb 22, 2012
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Santa Cruz CA
- Activity points
- 1,546
I considering ways to drive a high side switch without using an isolated supply for a gate driver.
The first stage of my project is to chop 300 to 450 volts DC with a high current IGBT or Darlington emitter/source follower down to a maximum of 170 volts at several amps (15 or less). The switched side will feed a 200 to 500 millihenry toroid and a capacitor (TBD based on load and H bridge in stage 2). Details are evolving from my earlier posts so I won't elaborate here.
1: I have several VICOR isolated DC - DC converters (200 to 400 VDC in, 15 (or 24) VDC out) that I will need to protect from overvoltages. They will power the high side gate drivers with several amps if needed. I have solved that problem but it is complicated and messy.
2: I am wondering if anyone has used a dozen or more forward biased high current silicon diodes between the power input and the collector/drain of a NPN darlington or NFET or IGBT to provide 10 to 15 volts to drive the base/gate ? Since the diodes carry the full current of the rest of the circuit they will have to dissipate several watts and may be stud types bolted to a heat sink. Regulation is not critical. If I use overkill on the diodes, I hope to simplify this part at the expense of a dozen or more watts of wasted heat.
3: I may use a SMPS boost to to a specific voltage or even add ano3:ther inverted boost SMPS to get a relative minus 5 volts to turn the gate off hard.
4: if I use a Darlington, I assume I will need fewer volts (diodes *.7) but will have to account for current pulses into a base rather than current peaks as seen into a gate ?
I recently picked up a few isolation tranformers, an isolated variac, and a 500 VA isolated transformer that takes 120/240 in and puts out 240/480 depending how I connect the split primaries and secondaries so I can control the volts as I work things out.
Any thought would be appreciated.
Thanks,
Brian in Santa Cruz.
Thanks,
