gorkin
Advanced Member level 1
Hello brothers!
I would like know if possible activate the IN pin of BSP752R high side switch directly from a microcontroller 3.3V output pin.
In my application, I need four high side swiches and I woul like use infineon BSP752R part drived (activated) directly from four outputs pins of my microcontroller (each output pin of microcontroller is connected in VIN pin of BSP752R). There need a special care to make this? With the voltage applied in to VIN input switches, they will full activate de output?
Thanks in advance, Christian
