themaccabee
Full Member level 4
High side Mosfet Driver
I need to drive a MOSFET to generate a constant current source,
the idea is to drive the MOSFET in linear region to obtain a set current corresponding to the VOLTAGE Value .
Is this configuration ok?
Is npn transistor can be replaced by an n channel mosfet?Is there any advantage in using mosfet instead of npn transistor
Thanks
Regards
Thanks
Regards
