I need to find a solution to have a high side current monitor for high common mode voltage inputs and at high temperatures (stable up to 125C).
Currently, I have tried using the INA193 shunt monitor IC with a 7.5 ohm shunt and common mode voltage that can reach up to 58VDC (which the IC claims to be able to handle). The supply is 3.6V and GND. Load current varies between 10mA and 30mA.
At ambient, the circuit works fine, but if I put any heat applied to the chip the gain appears to drift downward. It is specified to be 20V/V but seems to drift down to almost 10V/V at temperature. Letting it cool restores the gain to workability.
Is there a solution to this issue or another high side current monitor solution I could use better? Thank you.
