Hii...
I just wondering, which typologies are best for high power solar charging related application?
Suppose, I have 480Ah rated battery and want to charge it at a rate of 60A, What topology should I use?
Also, I have found lots of 20A Ics from Linear Technologies and Texas Instruments, but is it a good way to cascade three chargers in parallel and get 60A output?
Also, in several places I had seen a micro-controller and PWM to charge battery. I want to eliminate micro-controller, Is it necessary for charging a battery with higher Amp hour rating?
Thanks.
