Hello Brad, I like your circuit, the addition of some small inductors in series with C2,4,6 and the far left upper diode will make it efficient at 10kHz and higher frequencies...
thanks...the reason why I ask this question is that I found that the charge pump usually used in that application which only required low current...and I want to know if there is any fundamental limitation about it...now I know it is possible to get high current...
what kind of charge pump what u build...cuz I only now dickson charge pump and it required a non-overlapping clock generator...I want to simulate ur charge pump...can u provide me more detail about ur circuit? many thanks!!!
