of course a op amp needs a dual supply DOH!!!
Is anyone kind enough to do a schematic for dual supply? or where do I put the +/-
You correctly put +9V on pin 8 but you wrongly put 0V on pin 4 instead of a second battery that is -9V.where do I put the +/- ?
You can actually achieve any filter Q and respective peaking in the Sallen Key topology with gain = 1.The gain of this circuit is 1 because the opamp is a follower with a gain of 1. If the gain is increased to about 1.25 then it peaks at the cutoff frequency and if the gain is higher than about 1.6 then it oscillates. The ratio of the two capacitor values affects peaking or oscillation when the opamp gain is increased.
What is a "critical frequency"? Highpass and lowpass filters have a "cutoff frequency" where it is just beginning to filter and the output level is -3dB from the input level.Now how do I work out the critical frequency?
