[SOLVED] High Frequency PCB design
manchandaprabhav
Newbie level 5
Hello everyone,
I am designing a PCB for a diode mixer at 12 GHz.
So far, I have selected Rogers RO4350B as my substrate. Going with a single-layer microstrip design.
As I want to check my output at IF (50 MHz) with a varying load resistance, I am looking for a potentiometer.
The potentiometer range to be expected is 50 Ohms to about 100k Ohms. I have looked at a few options on Mouser, but there seems to be a lack of them for SMD technology.
Can someone help me find a good one?
Also, if someone has experience with a particular substrate, any tips on the layout or design?
Kind Regards,
Potentiometers are not used at RF frequencies. If you would like to use a variable Load, you should use Sliding Tuner or fixed resistor loads.( change by snap-on or any method )
@BigBoss, yes, Potentiometers are not used at high frequencies. But, as I have mentioned, my IF is at 50 MHz. This is why a potentiometer would do the job.
