The gap between high mm-wave band and far infrared is today a hot topic (0.1-10THz)!
Usually, if you have a single antenna, lens is the approach you should go for in case you need high-directivity antenna. One of (many) problems is the reflection on the lens-air interface.
EDIT:
"patch antenna" ... you mean planar antenna probably, right?
Again, the question is what are your requirements...
i think u shd go for lens antenna .. for a aptch antenna above 300ghz .. tyhe subs thickness will come in picometers.... thets are very tough to fabricate ..
can u specify for wht application u need this for ..
