khaled ragab
Junior Member level 1
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 #include<htc.h> #include"lcd_fns_4bit_hitech_roll.h" #define _XTAL_FREQ 20000000 #pragma config PBADEN = OFF #pragma config FOSC = HS #pragma config BOR = OFF #pragma config WDT = OFF unsigned int count=0; //----------------------------------------------------------------------------------------------------- //----------------------------------------------------------------------------------------------------- void init_interrupt_ports() { PEIE=1; GIE=1; INT0IE=1; INT1IE=1; ei(); TRISB=255; PORTB=0; TRISC=0; PORTC=0; } //----------------------------------------------------------------------------------------------------- //----------------------------------------------------------------------------------------------------- void tmr1_start (unsigned char sampling_freq) { //-------------------------------- //note : max sampling time (timer) = 520 ms => min sampling freq = 2 //max sampling time (unsigned char) = 255 => min sampling freq = 4 //-------------------------------- unsigned char sampling_time_ms; unsigned int set_value; float req_value; T1CON=0b00110001; sampling_time_ms = (1000/sampling_freq); //-------------------------------- //fosc:20mhz ---fosc/4---> 5mhz ---1:8prescaler---> 625khz ==> time of a single colck tick = 1000/750000 = 1.6*(10^-3)msec //1.3*(10^-3)msec * (2^16-1(no of tmr1 ticks)) = 87ms(timer max capacity) //-------------------------------- //to determine what value to set in the timers regs to count a certain time //max value = 2^16-1 = 65535 //required value = sampling_time_ms/(8*10^-3) //set_value = max value - required valuue //-------------------------------- req_value = ((sampling_time_ms*1000) / (1.6)); set_value = (int)(((2^16)-1)- req_value); TMR1L=set_value; TMR1H=(set_value>>8); } //----------------------------------------------------------------------------------------------------- //----------------------------------------------------------------------------------------------------- void interrupt ISR(void) { if(INT0IF==1) { count++; INT0IF=0; } } //----------------------------------------------------------------------------------------------------- //----------------------------------------------------------------------------------------------------- void main() { init_lcd(); init_interrupt_ports(); tmr1_start(20); while(1) { if(TMR1IF==1) { TMR1IF=0; gotorc(0,0); show_number(count); tmr1_start(20); } } }
this is the code i don't know where is the problem the intif is always zero never goes high
