hi friends, can any one give some basic programs using AT89c2051
karthikeyan0758
Newbie level 1
some basic programs, so that i can know the syntax........
What do you mean by basic programs?
Basic as in BASIC?
or basic as in assembly like blink LED?
or basic as in C to blink an LED, debounce a switch etc?
for BASIC, download and install BASCOM AVR, there would be number of sample/examples in the install directory.
for C, download and install uVision for C51, there are tons of examples in the install directory as well.
I can give you some programs written in assembly. Most are interfacing progs written on 89s5x but should fit into the 2kb space of 2051.
Learn the controller and its instruction set and start yourself and post the problem here for help...... always do a search in google or in this forum and then ask for help......
this might help you
' Description:
' Compiled by BASCOM 8051 Demo
' Home - MCS Electronics
$regfile = "REG51.DAT"
' 7 Segment Pattern Data
Const Segpat0 = &B11000000 ' 0 ****A***
Const Segpat1 = &B11111001 ' 1 * *
Const Segpat2 = &B10100100 ' 2 F B
Const Segpat3 = &B10110000 ' 3 * *
Const Segpat4 = &B10011001 ' 4 ****G***
Const Segpat5 = &B10010010 ' 5 * *
Const Segpat6 = &B10000010 ' 6 E C
Const Segpat7 = &B11011000 ' 7 * *
Const Segpat8 = &B10000000 ' 8 ****D***
Const Segpat9 = &B10011000 ' 9
Const Segpblk = &B11111111 ' 10 BLANK
Hour10 Alias P1.0
Led_am Alias P1.1
Led_pm Alias P1.2
Piezo Alias P1.3
Sw_alarm Alias P1.4
Sw_exit Alias P1.5
Sw_hour Alias P1.6
Sw_min Alias P1.7
Dim Icount As Word
Dim Clock_cent As Byte
Dim Clock_second As Byte
Dim Clock_min As Byte
Dim Clock_hour As Byte
Dim Alarm_min As Byte
Dim Alarm_hour As Byte
Dim Data_min As Byte
Dim Data_hour As Byte
Dim Tempa As Byte
Dim Tempb As Byte
Dim Tempc As Byte
Dim Beep As Bit
Dim Dot_high As Bit
Dim Dot_low As Bit
Dim Dot_alarm As Bit
On Timer0 Timebase ' Timer0 Interrupt
Config Timer0 = Timer , Gate = Internal , Mode = 2 ' Timer0 Auto Reload Timer Mode
Load Timer0 , 200 ' Auto Reload Constant 200 uSec
Start Timer0 ' Start Timer0
Enable Timer0 ' Enable Timer0
Enable Interrupts ' Enable All Interrupt
Icount = 0
Clock_cent = 0
Clock_second = 0
Clock_min = 0
Clock_hour = 0
Alarm_min = 0
Alarm_hour = 0
Beep = 0
Dot_alarm = 1
Main_clock:
If Clock_cent > 99 Then
Clock_cent = 0
Incr Clock_second
End If
If Clock_second > 59 Then
Clock_second = 0
Incr Clock_min
End If
If Clock_min > 59 Then
Clock_min = 0
Incr Clock_hour
End If
If Clock_hour > 23 Then
Clock_hour = 0
End If
Data_min = Clock_min : Data_hour = Clock_hour
Gosub Dot_proc
Gosub Clock_disp
If Sw_alarm = 0 Then
Gosub Alarm_proc
End If
If Sw_min = 0 Then
Clock_second = 0
Incr Clock_min
Clock_min = 0
End If
Waitms 100
End If
If Sw_hour = 0 Then
Incr Clock_hour
Clock_hour = 0
End If
Waitms 100
End If
If Dot_alarm = 0 Then
If Clock_hour = Alarm_hour Then
If Clock_min = Alarm_min Then
Set Beep
Else
Reset Beep
End If
Else
Reset Beep
End If
Else
Reset Beep
End If
Goto Main_clock
Clock_disp:
Tempa = Data_min Mod 10 : Gosub Patconv
Tempb = Tempb And &H7F
End If
P3 = Tempb
Tempa = Data_min / 10 : Gosub Patconv
If Dot_high = 0 Then
End If
P2 = Tempb
If Data_hour < 12 Then
Reset Led_am : Set Led_pm
Tempc = Data_hour
Else
Reset Led_pm : Set Led_am
Tempc = Data_hour - 12
End If
If Tempc = 0 Then
Tempc = 12
End If
Tempa = Tempc Mod 10 : Gosub Patconv
If Dot_low = 0 Then
End If
P0 = Tempb
Tempa = Tempc / 10
If Tempa = 1 Then
Reset Hour10
Else
Set Hour10
End If
Return
Dot_proc:
If Clock_second < 30 Then
Reset Dot_low
If Clock_cent < 50 Then
Reset Dot_high
Else
Set Dot_high
End If
Else
Reset Dot_high
Reset Dot_low
Else
Set Dot_low
End If
End If
Return
Alarm_proc:
Set Dot_high : Set Dot_low
Data_min = Alarm_min : Data_hour = Alarm_hour
Gosub Clock_disp
Waitms 100
Alarm_loop:
Gosub Clock_disp
If Sw_min = 0 Then
Incr Alarm_min
If Alarm_min > 59 Then
Alarm_min = 0
End If
Waitms 50
End If
If Sw_hour = 0 Then
Incr Alarm_hour
If Alarm_hour > 23 Then
Alarm_hour = 0
End If
Waitms 50
End If
Set Dot_alarm
Goto Alarm_ret
End If
If Sw_exit = 0 Then
Reset Dot_alarm
Goto Alarm_ret
End If
Goto Alarm_loop
Alarm_ret:
Waitms 500
Return
Patconv:
Tempa = Tempa And &H0F
Select Case Tempa
Case 0 : Tempb = Segpat0
Case 1 : Tempb = Segpat1
Case 2 : Tempb = Segpat2
Case 3 : Tempb = Segpat3
Case 4 : Tempb = Segpat4
Case 5 : Tempb = Segpat5
Case 6 : Tempb = Segpat6
Case 7 : Tempb = Segpat7
Case 8 : Tempb = Segpat8
Case 9 : Tempb = Segpat9
Case Else
End Select
Return
Timebase:
Incr Icount
If Icount > 49 Then ' 49
Icount = 0
Incr Clock_cent
End If
If Beep = 1 Then
If Piezo = 1 Then
Reset Piezo
Else
Set Piezo
End If
End If
Return
'============================ END OF FILE ==================================
