Hi doubt in C programming
When a pointer is used to reference a structure, the structure pointer operator (->) is used:
message->frame_type=CAN_FRAME_STD;
is the same as
(*message).frame_type=CAN_FRAME_STD;
check
Alex
My doubt got cleared, i was having doubt on that reference place
struct date {
int month, day, year;
struct date todays_date, *date_pointer; //
date_pointer = &todays_date; //
The link you given was nice, thanks
this is a simple case of configuring the ECAN bus in the code...
both lines a & b are used to Define ECAN Message Buffers.
statement a : it is about Configuring DMA Channel 0 for ECAN2 Transmit (Remote Transmit Request)
ecan2msgBuf __attribute__ is the syntax that has to be used to define or use any statement here...
ECAN2MSGBUF ecan2msgBuf __attribute__((space(dma),aligned(ECAN2_MSG_BUF_LE NGTH*16)));
means you are trying to configure the size of the CAN BUFFER MESSAGE LENGTH...... space dma refers to initializing the DMA space , and the length alloted if 4 bytes *16) you have to align the memory read and write when you use DMA....
typedef unsigned int ECAN1MSGBUF [ECAN1_MSG_BUF_LENGTH][8];
is declaration of ECAN1 message buffer length 4* 8 = 32 bytes you are allocating the memory and allocating DMA to read 32 locations....
