coco85
Newbie level 3
I would like to know the consumed power and the output power of the VCO.
For the consumed power,
(1) First,I add ".print power" in the ".sp" file, run "hspice .sp >results",
and then grep "pow" from the file "results". The result is showns as
" power 1.000e-06 9.650e-02
total voltage source power dissipation= 9.650e-02 watts"
and a long list like
power 8.858e-02 1.203e-29 1.025e-28 8.631e-30 1.709e-33 4.908e-32
power 6.564e-33 7.430e-29 8.086e-33 1.252e-04 2.629e-04 1.070e-04
power 1.337e-05 5.258e-05 1.251e-04 3.138e-05 1.073e-08 3.251e-05
power 2.316e-06 3.918e-06 2.129e-08 3.678e-10 1.155e-09 9.727e-10
what are 1.000e-6 and the long list? (The simulation period is 10ns.)
(2) Second, if I use ".measure avg_pow AVG power from=0n to=5n"
file ".mt0" shows,
avg_pow temper alter#
0.1006 25.0000 1.0000
If I change the end time, such that ".measure avg_pow AVG power from=0n to=10n", ".mt0" shows
5.234e-02 25.0000 1.0000
Why the "avg_pow" changes according to time period?
Which value is the actual total power consumption? from (1) or (2)?
For the output power, I add ".print I(r0)" (r0 is a 50 Ohm load) to simulate the current through the load and thus get the output power into the load. But when I "grep r0" or "grep current" from the file "results", I cannot tell which value is the one I want. Should this value be written to "results" or some other files?
Thanks very much!!
file ".mt0" shows,
Thanks very much!!
