I am now moving moving my hfss designs from one hard disk to another. While I am doing that, I am curious about the function of the hfssresults folder. If it only contains the result of the design data, does it mean that I can only copy the .hfss file without the hfssresults folder which takes a lot of memory?
If you just copy the .hfss file without the corresponding results folder, you will lose the results so you have to simulate again. If you copy both, no need to simulate again.
Because the results folders are so large, I was just wonder whether I can copy the .hfss file only or not. As you said, results will be lost. Thank you for your answer.
