HFSS v9.0 help with (unwanted) objects intersecting
Athina
GR
clone tool objects before subtracting hfss
Good morning to all. I am new to this forum and in HFSS (first design for me) and I have encountered a problem in my design. I am trying to draw a polyedron inside another polyedron (outside-->vacuum, inside-->perfect conductor) but I get the error message that the 3D model is incorrect because these two intersect. I have the design (I do not know if I am allowed to post it or s'th-i am new here) if my problem is not clear. Does anyone know what I should do to make that work? This (these 2 polyedrons) are supposed to be the SMA that will be connected to the patch I want to simulate. Any ideas???
thx in advance
ps. The word is NOT fix but "p a t c h" in the last sentence. In my pc I get the word fix instead so I am just letting u know!
bevits
Newbie level 1
Try subtracting the two objects and make sure to select "Clone tool object" before you do so or else you will lose part of the geometry.
HFSS does not like intersecting objects, even if the intersecting region is only 0.00000000001 m thick
Hope this helps.
Best Regards,
Vittal
