HFSS: solve inside and finite conductivity boundary
qqpost
Member level 1
Hi everyone,
I read a paragraph in HFSS online help and I am not quite understand it. Just post and see if there anyone has some understand towards this one.
It is under keyword "Solving inside or on the Surface"
HFSS implicityly places a finite counductivity boundary condition on the surfaces of an object that should not be solved inside based on the material properties of that object. You can also incorporate a DC Thickness for the implicity boundary condition by setting an appropriate thickness value.
My question is what is the object that should not be solved inside based on the material?? Does it correlate to the Solve Inside Threshold? And when I set a solve inside, for example, a copper metal, do I still need to set the finite conductivity boundary?
Thanks!
bya036
Junior Member level 1
Objects with conductivity higher then 10^5 will not be soved inside automatically.
Reactions: drops
    drops
qqpost
Member level 1
But if I keep the threshold at 10^5, when I choose the solve inside for a component which is, for example copper, it will show the warning message that they may need a large mesh. Do I need to increase this threshold?
And is the solve inside on the contrary to "finite conductivity boundary"? Can I set these two on one structure? And what will HFSS solve for this structure?
Thank you so much for your time.
bya036
Try both methods ( with and without "solve inside") and check the difference (don't forget to update). The mesh will obviously increase because now the mesher should mesh the conductor inside.
