HFSS PORT ERROR
ghoshdeba
Newbie
Error is coming for designing coax feed Port refinement, process hf3d: '1' conductors touch lumped port '1', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup.
What will be the solution? Please suggest me.
LaTeX Commands Quick-Menu:
