HFSS microstrip patch antenna
Sumer19
Junior Member level 1
I am designing a circular patch antenna with stub. I need to connect stub at angle 112 degree from transmission line feed. how can i rotate at particular angle in HFSS.
Moving object with certain angle..
second any one please tell me that transmission line feed formulaes for circular patch and any thumb rule for line feed. similar for stub formulaes. stub length, stub width etc.
Line feed length, line feed width and angle.
rizoeda
Member level 1
Edinburgh, Scotland
Moving object with certain angle...
first create and choose proper Coordinate System, (i.e. go to Modeler> Coordinate System> Create> Relative CS> Offset and then choose your rotation center as CS center). Then select the object you want to rotate and go to Edit> Arrange> Rotate and fill in the appearing dialogue box 112 degree. I hope it helps.:smile:
