HFSS Lumped Gap Source
desertfox
lumped port calibration
HFSS newbie here
I am trying to simulate an Interconnect line test structure mouted on a Silicon substrate. Its basically 2 lines in Parallel and i need to define 2 ports on either side to get the S Parameters. Question is, If I use Lumped Gap source to define the Ports,
How do I Draw the Calibration and Impedance Lines? Can Someone describe how to do it or Does anyone have any Graphical Examples or links?
Thanks
Added after 52 minutes:
I have attached a Drawing of the Structure... it is Top view, and i have labled the Pads a,b,c and d for easy reference... where do the impedance and calibration lines go?
gap source
If you have HFSS_9 you can use a driven terminal solution method.
Go to the **broken link removed** and you'll find many examples in the folder Reviews and News.
lumped ports silicon substrate
Thanks, but i have looked at some of the articles but i couldnt find any description on how to define a port..
I'm using HFSS 8.5 and i believe there is a choice of eigenmode or driven solution.. i chose driven.
So far i have been getting an error message that the port is not defined correctly as the conductors are shorted.. the pictures show how i assigned the T, C and I lines (Terminal, Calibration and Impedance).. can someone comment on this assignment?
hfss coplanar lumped-gap port
for your model
I would draw a rectangle between the
terminal a and b and a rectangle between terminal c and d
Select these rectangle and assign lumped port to them.
Draw impedance and calibration lines from the middle of the edge
on terminal a to the middle of the edge on terminal b
Do the same for terminal c and d
You should think to lumped porte as a kind of voltage source
terminal line indicate the points where you attach the terminal of the voltage source
Rugbyfun
number terminal hfss
I wouldn't use lumped source for this configuration. lumped source should occupy tiny space (so that the fields between the two terminals are kind of uniform, so that a voltage can be defined...). The "gap" in your case is too wide. So change to wave port (there is a tutorial somewhere in this forum for coplanar waveguide). If gap source is absolutely required, you should make it a 4 port network, then figure out how to obtain the 2 port s-parameter from your 4 port result.
lumped gap sources hfss
rugbyfun,
i think it works, thanks.. heres another question... if i have a piece of metal over an oxide layer and a substrate, and i want to find the s parameters of the metal (refer to the picture) How do i assign the ports if i use Lumped gap source, now that i dont have a ground? Wave ports wont work because wave ports are not supposed to touch "existing materails" (this structure is enclosed in an AirBox)
lumped ports hfss terminal
I have difficulty in understanding the use of the lumped source.Could you guys explain when and how do I use the lumped source? Thanks.
hfss gap source
I think lumped gap source ports are only useful when you need an excitation port inside a structure. If all the ports are defined on the border of the box, you only have to use wave ports.
For your problem, I think wave port with terminal activated is more appropriate. The terminal can be defined between the two lines. I always set calibration and impedance lines using the same coordinates than terminal arrow.
Are these two lines microstip ones with gnd plane under them ?
Added after 8 minutes:
>evoplus
To understand lumped gap source ports, try reading this file. It explains how to define ports in HFSS 8.5
(It comes from HFSS CDROM)
