HFSS integration line
samstag
Newbie level 1
Newbie level 1
Hello everyone,
I am simulating parametrized microstrip to slot transition with two wave ports with defined integration lines. I have found that the integration line changes its direction while changing parameters. Is there any possibility to define integration lines with variables?
Thanx.
No, unfortunately you can't parameterize integration lines. I talked with Ansys about this a while back. Look closely at what points your integration lines are snapped to and see if there's a way you can modify the geometry so that the two points don't become offset.
