gultepee
Newbie level 6
I want to simulate an antenna as a receiver using HFSS. I add an incident plane wave excitation and a lumped port to my system.
I edited the scaling factors as
incident wave -> 1
lumped port -> 0.
Is this a good way to simulate a receiving antenna? And also, is "radar cross section" is a good method understand how good the antenna is?
Thanks,
Added after 4 hours 34 minutes:
I learned that scaling the sources is not a bad way to simulate a receiving antenna.
And, instead of "radar cross section", calculating absorbed power at lumped port is the correct way.
If you have any suggestions on how to calculate absorbed power at the port by using field calculator, please write.
Thanks,
incident wave -> 1
lumped port -> 0.
Thanks,
Thanks,
