I'm currently working on designing a rectangular microstrip antenna and I can find the S11 but not sure how to get S12 parameter?
Also, how can i get the actual distance coverage of my antenna? I can see there is a directivity and power of radiation but not sure how to convert those to actual distance?
Also, the angle coverage??
Please let me know if you have any idea what i'm talking about??
as sv has noted, unless you have a two port antenna, you will only have s11. you can use friis equation to get a line of site distance for two antennas if you know the input power at the tx side using
Pr/Pt = GtGr(lambda/(4pi*r) where r is radiation distance Pr & Pt are power at receive and transmit ends and Gt and Gr are gains.
Thank you sv1437 that actually makes sense! Do you know how to find the actual distance and angular coverage in HFSS? I can find multiple results but still don't know how to get those?
Thanks for the info but where did you get this formula and how can I get those parameters? Do you think I can get them from HFSS directly? The think is that I'm building a rectangular array antenna and I'm trying to add array patches to increase the distance coverage and adjusting the angle by adding arrays!
Hi ihamieh,
You cannot get the information about the actual distance covered by antenna using HFSS results. Using the Friis's equation mentioned by ghb, you can calculate that. But for that you need to know the gain of the Tx antenna, power transmitted and power received and the remaining parameters.
And what 'ghb' meant by a 2-port antenna is that, for doing the Friis measurement you need to have two antennas (one Transmitting and other receiving).
just to confirm. to use friis equation a couple of things must be known.
Tx power - should be easily achievable
Gt,Gr - sounds as if you're working on one of these, you would have to know the antenna on the other end or assume its a duplicate of what you're currently evaluating.
Rx power - if the goal is to find some distance where the system would still work you should be able to think along these lines - lets assume you know the receiver sensitivity or the min power that the receiver needs. lets assume thats -100dBm. well now you should be able to use Friis to calculate what distance can i place these two antennas knowing this is the received power - 100dBm
Hi ihamieh,
