matrix solver exception: out of memory
I keep getting this out of memory error in HFSS, but the problem is I still have free memory and my computer never even started using the swap space.
HFSSDesign1 (DrivenModal)
[error] Adaptive solution setup, process hf3d error: Matrix solver exception: out of memory.. (10:59 AM Jun 12, 2009)
[error] Simulation completed with execution error on server: Local Machine. (10:59 AM Jun 12, 2009)
At the time of this error I had 2.5 GB free out of 8 GB of ram and the swap space was unused.
I am using HFSS 11.1 on Debian with a 64 bit kernel. I have an AMD 64bit cpu with 8GB of ram and swap space set to 10GB.
This is an odd error and it is preventing me from simulating anything beyond a simple microstrip line.
If anyone has any input or as seen this error, please let me know. Is there some limitation on the amount of ram hfss can use? Maybe the matrix solver they release for Linux is only 32bit, that is the only logical explanation I can think of at th moment.
Added after 43 minutes:
Solved the problem, it was in fact using the 32 bit binaries. To fix, simply copy the binaries from the ansoftbin64 directory to the root directory where hfss is installed and overwrite the 32 bit binaries.
I think that was the last part to getting HFSS to work perfectly and install on any linux distribution!
