HFSS Equation Based Surface Not Smooth
Zangetsu57
Member level 4
Member level 4
Hello all,
I've drawn an equation based surface based on exponential functions (for an exponential taper), but the surface came out to be a rough approximation of line segments. Is there a way to tell HFSS to use more points to allow for a smoother curve?
hello Zangetsu,
yes you can make the surface more smoother by adding more number of coordinates(x,y,z) to your equation(of which you have drawn the surface). Check the help section of HFSS, you will definately get the matter there that you need.
