sandbo
Newbie level 6
- Joined
- Jun 11, 2014
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 141
Hello,
I am using Driven Terminal for my simulation with some 50Ohm CPW waveguide.
On getting the results, I want to simulate for the given power in dBm, how much current I will end up running through some sections.
However in Driven Terminal the excitation is in terms of incident voltage.
May I know if I should take this voltage as Vpp, Vrms, or Vpeak?
For example, I know the power running through the line would be ~-40dBm, from this website I see the conversion:
http://ifmaxp1.ifm.uni-hamburg.de/DBM.shtml
[dBm] [Watts] [Volts]rms [Volts]p [Volts]pp
-40 0.100E-06 2.236 mV 3.162 mV 6.324 mV
May I know which number I should set for the incident voltage?
Many thanks.
Many thanks.
