Register Log in
HFSS Antenna Array Simulation
ctyz
I am trying design a basic array that has 2 elements. I want to create Cardioid Pattern, the distance between two antenna is quarter wavelength and phases are 0 and 90 degree. But the result is not correct. Can someone help me to find what i am doing wrong?
PlanarMetamaterials
Edmonton, Canada
Hi ctyz,
I took a look at your file, and the setup looks correct. The behavior you're looking for may simply be slightly outside of the narrow frequency range you're observing -- I would try increasing the frequency range and see what happens. Also, for best results, use a discrete frequency sweep.
Good Luck!
ctyz
thanks a lot i will try :)
Toggle Sidebar
