crayon
Newbie level 5
Hi everyone,
I am using HFSS12 and Ansoft Designer 5 for EM co-simulation. I built some simple CPW structures in HFSS and incorporated them into Ansoft Desinger using dynamic link to HFSS. But the simulation results (S-parameters) given by HFSS and nexxim were significantly different (larger than 10dB).
The structure was a CPW bend. I used Driven Terminal solution type and two wave ports, normalized to 50 ohm. In Ansoft Designer, I connected the two pins of the HFSS CPW bend component to two 50 ohm terminations. The S-parameters given by Ansoft Designer was quite different from that given by HFSS directly. The HFSS results seemed more reasonable. So I was confused...
In the past I used Agilent ADS to import the S-parameters generated by HFSS for co-simulation and it worked great. I thought Ansoft Designer would provide a smoother connection to HFSS.
Thanks for inputs!
Thanks for inputs!
