hf materials for digital PCB
buenos
Advanced Member level 3
Sunnyvale, California, USA
hi.
who uses high frequency dielectric materials for high speed PCB designs, who dont, and why?
in an AMD appnote they use standard FR4 for a board, where the highest speed bus is 400MHz DDR memory bus.
for a same speed board, intel uses some HF material, with Er about 3.2. In the appnote, they tell the width and thickness, 4/5 mils. they want 55 ohm striplines. this is only possible with Er=3.2 nad with a HF material.
so is it needed or not?
CDRCDR
Member level 4
HF materials such as Rogers and Gentek are used in 10Gbps applications. For applications such as several hundered MHz,FR4 is more than enough.
buenos
with one impedance calculator it needs Er=3.2 for 55 ohm (at 5mil/5mil) with another calculator it needs 4.5 which is the normal FR4.
so i am confused.
Added after 1 hours 25 minutes:
i checked again, ad yes:
high enough impedances and high enough density on inner layers is only possible with low Er materials.
with normal FR4 a 55 ohm trace on inner layers is only possible with thickness of 0.2mm, but then the trace separation on a high speed bus has to be 0.4mm which can not produce dense enough PCB for a very complex circuit with 1000 pin BGAs.
