hex file converting due to old version of mikroC pro for pic
flamesier
Newbie level 6
my mikroC software seems to be outdated. V6.0.0
can anyone help to convert this code to hex file please.
need it badly.
thanks.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
// VARIABLES
  char second = 0; char second_old = 0;
  char minute = 0; char minute_ten = 0; char minute_one = 0;
  char hour = 0; char hour_ten = 0; char hour_one = 0;
  char counter_1=0; char counter_2=0;
  unsigned temp = 0; char temp_ten=0; char temp_one=0; char temp_neg=0;
  char blink=0;
  char i=0;
void send_to_max7219(char address,char data) {
  PORTC.F6 = 0; // LOAD(CS) LINE LOW
  Spi_Write(address);
  Spi_Write(data);
  PORTC.F6 = 1; // LOAD(CS) LINE HIGH
void init_MAX7219() {
  send_to_max7219(0x09,0xFF);// BCD Mode Code B
  send_to_max7219(0x0A,0x0F);// INTENSITY MAX
  send_to_max7219(0x0B,0x03);// SCAN ONLY DIGITS 0,1,2,3
  send_to_max7219(0x0C,0x01);// TURN ON
  send_to_max7219(0x00,0x0F);// TEST OFF
void show_temp() {
  // READ AN0 INPUT 50 TIMES CUMULATIVELY
  temp=0;
  for (i=0;i<=49;i++) {
    temp = temp+ Adc_Read(0);
    delay_ms(1);
  temp=temp/50; //CALCULATE THE AVERAGE
  temp = temp*4.57;//CALCULATE THE SENSOR OUTPUT in mV
  // TEMPERATURE POSITIVE OR NEGATIVE?
  if (temp>=2730) {
  temp = temp-2730; temp_neg=0;}
  else {temp=2730-temp;temp_neg=1;}
  // CONVERT TEMPERATURE VALUE INTO BCD FORMAT
  temp=Dec2Bcd16(temp);
  // MAX7219 NO DECODE MODE
  send_to_max7219(0x09,0x00);
  // DISPLAY THE MINUS SIGN IF TEMP IS NEGATIVE
  if (temp_neg) {
    send_to_max7219(0x01,0x01);  }
  else {
    send_to_max7219(0x01,0x00); }
  // SEPERATE THE TEMPERATURE DIGITS
  temp_one=(temp>>4)&0b00001111;
  temp_ten=(temp>>8)&0b00001111;
  // DISPLAY THE TEMPERATURE DIGITS
  if (temp_one==0x00) {send_to_max7219(0x03,0x7E);}
  else if (temp_one==0x01) {send_to_max7219(0x03,0x30);}
  else if (temp_one==0x02) {send_to_max7219(0x03,0x6D);}
  else if (temp_one==0x03) {send_to_max7219(0x03,0x79);}
  else if (temp_one==0x04) {send_to_max7219(0x03,0x33);}
  else if (temp_one==0x05) {send_to_max7219(0x03,0x5B);}
  else if (temp_one==0x06) {send_to_max7219(0x03,0x5F);}
  else if (temp_one==0x07) {send_to_max7219(0x03,0x70);}
  else if (temp_one==0x08) {send_to_max7219(0x03,0x7F);}
  else if (temp_one==0x09) {send_to_max7219(0x03,0x7B);}
  if (temp_ten==0x00) {send_to_max7219(0x03,0x7E);}
  else if (temp_ten==0x01) {send_to_max7219(0x02,0x30);}
  else if (temp_ten==0x02) {send_to_max7219(0x02,0x6D);}
  else if (temp_ten==0x03) {send_to_max7219(0x02,0x79);}
  else if (temp_ten==0x04) {send_to_max7219(0x02,0x33);}
  else if (temp_ten==0x05) {send_to_max7219(0x02,0x5B);}
  else if (temp_ten==0x06) {send_to_max7219(0x02,0x5F);}
  else if (temp_ten==0x07) {send_to_max7219(0x02,0x70);}
  else if (temp_ten==0x08) {send_to_max7219(0x02,0x7F);}
  else if (temp_ten==0x09) {send_to_max7219(0x02,0x7B);}
  // DISPLAY THE DEGREE SIGN
  send_to_max7219(0x04,0x62);
void main() {
  // INITIALIZE SPECIAL FUNCTION REGISTERS
  ADCON1=0b00001110; // SELECT THE ANALOG INPUTS
  TRISC = 0b00010000; // ASSIGN DIRECTIONS FOR PORTC
  TRISB = 0b11111111; // ASSIGN DIRECTIONS FOR PORTB
  TRISA = 0b00000001; // ASSIGN DIRECTIONS FOR PORTA
  PORTC.F6 = 1; //LOAD(CS) LINE IS INITIALLY LOW
  // INIT HW SPI
  Spi_Init_Advanced(MASTER_OSC_DIV16,DATA_SAMPLE_MIDDLE,CLK_IDLE_LOW,LOW_2_HIGH);
  // INIT SW I2C
  Soft_I2C_Config(&PORTB, 1, 0);
  while(1) {
  init_MAX7219();
  // READ SECOND, MINUTE and HOUR INFO FROM DS1307
  Soft_I2C_Start();
  Soft_I2C_Write(0xD0);
  Soft_I2C_Write(0x00);
  Soft_I2C_Start();
  Soft_I2C_Write(0xD1);
  second = Soft_I2C_Read(1);
  minute = Soft_I2C_Read(1);
  hour = Soft_I2C_Read(0);
  Soft_I2C_Stop();
  // SEPERATE THE HOUR AND MINUTE DIGITS
  hour_one = 0b00001111 & hour;
  hour_ten = (hour >> 4) & 0b00001111;
  minute_one = 0b00001111 & minute;
  minute_ten = (minute >> 4) & 0b00001111;
  // BLINKING AND TEMP. DISPLAY PERIOD
  if (second != second_old) { // DETECT A SECOND
    counter_1++;
    counter_2++;
    second_old=second;
    if (counter_1==1) { // BLINK EVERY 1 SECOND
       counter_1=0;
       blink=~blink;
    if (counter_2==15) { // DISPLAY TEMP EVERY 15 SECONDS
      counter_2=0;
      show_temp();
      delay_ms(3000); // DISPLAY FOR THREE SECONDS
      send_to_max7219(0x09,0xFF); // SET BCD CODE B
  // MANUALLY SHOW TEMP IF SW2 IS PRESSED
  if (PORTB.F3==0) {
    counter_2=0;
    show_temp();
    delay_ms(3000);
  // DISPLAY THE HOUR DIGITS
  if (hour_ten == 0x00) { // IF THE DECIMAL DIGIT IS 0
     send_to_max7219(0x01,0x0F);} // THEN DISPLAY NOTHING IN FIRST DIGIT
  else {
     send_to_max7219(0x01,hour_ten);}
  if (blink==0xFF) {
     hour_one|=0b10000000;}  // DETERMINE THE DOT STATUS OF THE 2nd DIGIT
  else {
     hour&=0b01111111;}
  send_to_max7219(0x02,hour_one);
  // DISPLAY THE MINUTE DIGITS
  if (blink==0xFF) {
     minute_ten|=0b10000000;} // DETERMINE THE DOT STATUS OF THE 3th DIGIT
  else {
     minute_ten&=0b01111111;}
  send_to_max7219(0x03,minute_ten);
  send_to_max7219(0x04,minute_one);
  // INCREASE THE HOUR IF SW IS PRESSED
  hour_one&=0b01111111;
  if (PORTB.F2==0) {
    if (hour_one<=0x08) {
      if ((hour_ten==0x02) && (hour_one==0x03)) {
      hour_one=0;
      hour_ten=0; }
      else {
      hour_one++;}
    else {hour_one=0x00;
         if (hour_ten<=0x1) {
         hour_ten++;}
         else { hour_ten=0x00;}
    // WRITE THE NEW HOUR VALUE TO DS1307
    hour_ten = (hour_ten<<4)&0b11110000;
    hour = hour_one|hour_ten;
    Soft_I2C_Start();
    Soft_I2C_Write(0x02);
    Soft_I2C_Write(hour);
    Soft_I2C_Stop();
    do {} while (PORTB.F2==0) ; // SW DEBOUNCE
  // INCREASE MINUTE IF SW3 IS PRESSED
  if (PORTB.F4==0) {
    if (minute_one<=0x08) {
      minute_one++;
    else {
         if ((minute_ten==0x05) && (minute_one==0x09)) {
         minute_one=0x00;
         minute_ten=0x00;  }
         else if (minute_ten<=0x05) {
         minute_ten++;
         minute_one=0x00;}
         else {
         minute_ten=0x00;
         minute_one=0x00;}
    // WRITE THE NEW MINUTE VALUE TO DS1307
    minute_ten = (minute_ten<<4)&0b11110000;
    minute = minute_one|minute_ten;
    Soft_I2C_Start();
    Soft_I2C_Write(minute);
    Soft_I2C_Stop();
    do {} while (PORTB.F4==0); // SW DEBOUNCE
You do not need to get others to compile for you. Upgrade of ME compilers is free.
... besides, you have not provided enough information for someone else to compile anyway.
