helping on writting comments
H00
Newbie level 2
Hi everybody
I want to write comments for those projects
first one is
Interfacing a Key Board to the Display Via 8051 microcontroller
RS      REG     P1.5
RW      REG     P1.6
EN      REG     P1.7
LCMBUS  REG     P0
        ORG     000H
	JMP	MAIN
	ORG	003H
	JMP	INT0
	ORG	100H
MAIN:
        MOV     SP,#60
	MOV	P1,#0FFH
	MOV	IE,#10000001B
	SETB	IT0
        CLR     EN
	CALL    LCMINIT
        MOV     A,#10000000B	;SET DDRAM ADDRESS
        CALL    WRINS
	JMP	$
INT0:
	CLR	EA
	CLR	C
	MOV	A,P1
	ANL	A,#0FH
	MOV	B,A
	SUBB	A,#10
	JC	NUMBER
	MOV	A,B
	ADD	A,#37H
	JMP	DISP
NUMBER:
	MOV	A,B
	ADD	A,#30H
DISP:
	CALL	WRDATA
	CALL	RDINS
	ANL	A,#01111111B
	MOV	B,A
	SUBB	A,#14H
	JNZ	TESTB
	MOV	A,#11000000B
	CALL	WRINS
TESTB:
	MOV	A,B
	SUBB	A,#54H
	JNZ	RETURN
	MOV	A,#10000000B
	CALL	WRINS
RETURN:
	SETB	EA
	RETI
WRINS:
        CALL    CHKBSY
        CLR     RS
        CLR     RW
        SETB    EN
        MOV     LCMBUS,A
        CLR     EN
        RET
RDINS:
	CALL	CHKBSY
	CLR	RS
	SETB	RW
	SETB	EN
	MOV	A,LCMBUS
	CLR	EN
	RET
WRDATA:
        CALL    CHKBSY
        SETB    RS
        CLR     RW
        SETB    EN
        MOV     LCMBUS,A
        CLR     EN
        RET
CHKBSY:
        MOV     LCMBUS,#0FFH
        CLR     RS
        SETB    RW
        SETB    EN
        MOV     C,LCMBUS.7
        CLR     EN
        JC      CHKBSY
        RET
LCMINIT:
        MOV     A,#00110000B
        CALL    WRINS
        MOV     R6,#41		;DELAY 4.1mS
$1:
        MOV     R7,#50
        DJNZ    R7,$
        DJNZ    R6,$1
        MOV     A,#00110000B
        CALL    WRINS
        MOV     R7,#50		;DELAY 100uS
        DJNZ    R7,$
        MOV     A,#00110000B
        CALL    WRINS
        MOV     A,#00111000B	;FUNCTION SET
        CALL    WRINS
        MOV     A,#00001000B	;DISPLAY OFF
        CALL    WRINS
	MOV	A,#00000001B	;DISPLAY CLEAR
	CALL	WRINS
        MOV     A,#00000110B	;ENTRY MODE SET
        CALL    WRINS
	MOV	A,#00001111B
	CALL	WRINS
        RET
PRTSTR:
        MOV     A,#0
        MOVC    A,@A+DPTR
        CJNE    A,#'$',PRINT
        JMP     ENDPRT
PRINT:
        CALL    WRDATA
        INC     DPTR
        JMP     PRTSTR
ENDPRT:
        RET
        END
the second proj
Message display on LEDs-Matrix.
	ORG	000H
	CLR	P1.7
START:
	MOV	DPTR,#TABLE
	MOV	R0,#36		;TOTAL 36 CHAR.
NEXTC:
	MOV	R3,#20
REPEAT:
	MOV	R2,#10000000B	;COLUMN
	MOV	R1,#0
NEXT:
	MOV	A,R1		;DATA POINTER
	MOVC	A,@A+DPTR
	MOV	P2,A
	MOV	A,R2
	MOV	P0,A
	CALL	DELAY
	RR	A
	MOV	R2,A
	MOV	P0,#00H		;TURN OFF LED
	INC	R1
	CJNE	R1,#5,NEXT
	DJNZ	R3,REPEAT
	INC	DPTR		;NEXT CHAR.
	INC	DPTR
	INC	DPTR
	INC	DPTR
	INC	DPTR
	DJNZ	R0,NEXTC
	JMP	START
TABLE	DB	3EH,48H,88H,48H,3EH	;A
	DB	FEH,92H,92H,92H,6CH	;B
	DB	7CH,82H,82H,82H,44H	;C
	DB	FEH,82H,82H,44H,38H	;D
	DB	FEH,92H,92H,92H,82H	;E
	DB	FEH,90H,90H,90H,80H	;F
	DB	7CH,82H,92H,94H,5EH	;G
	DB	FEH,10H,10H,10H,FEH	;H
	DB	00H,82H,FEH,82H,00H	;I
	DB	04H,02H,82H,FCH,80H	;J
	DB	FEH,10H,28H,44H,82H	;K
	DB	FEH,02H,02H,02H,02H	;L
	DB	FEH,40H,30H,40H,FEH	;M
	DB	FEH,20H,10H,08H,FEH	;N
	DB	7CH,82H,82H,82H,7CH	;O
	DB	FEH,90H,90H,90H,60H	;P
	DB	7CH,82H,8AH,84H,7AH	;Q
	DB	FEH,90H,98H,94H,62H	;R
	DB	64H,92H,92H,92H,4CH	;S
	DB	80H,80H,FEH,80H,80H	;T
	DB	FCH,02H,02H,02H,FCH	;U
	DB	F8H,04H,02H,04H,F8H	;V
	DB	FCH,02H,1CH,02H,FCH	;W
	DB	C6H,28H,10H,28H,C6H	;X
	DB	E0H,10H,0EH,10H,E0H	;Y
	DB	86H,8AH,92H,A2H,C2H	;Z
	DB	7CH,8AH,92H,A2H,7CH	;0
	DB	00H,42H,FEH,02H,00H	;1
	DB	42H,86H,8AH,92H,62H	;2
	DB	84H,82H,A2H,D2H,8CH	;3
	DB	18H,28H,48H,FEH,08H	;4
	DB	E4H,A2H,A2H,A2H,9CH	;5
	DB	3CH,52H,92H,92H,0CH	;6
	DB	80H,8EH,90H,A0H,C0H	;7
	DB	6CH,92H,92H,92H,6CH	;8
	DB	60H,92H,92H,94H,78H	;9
; DELAY 5mS
DELAY:
	MOV	R6,#10
DL1:
	MOV	R7,#249
	DJNZ	R7,$
	DJNZ	R6,DL1
	RET
	END
That's a strange request. If you wrote the code, you should also be able to write the comments?
I'm guessing this is a school assignment you're too lazy to do on your own?
no its college assignment, also no I didn't write the program
I wrote some comments in the first one but my DR said it is wrong ...
this is what I wrote
RS      REG     P1.5  ; assign RS to P1.5
RW      REG     P1.6
EN      REG     P1.7
LCMBUS  REG     P0
        ORG     000H	; entry address for 8051 RESET
 It shows memory location,( where the program to start)					JMP	MAIN	; MAIN starts beyond interrupt vector space
	ORG	003H	; vector address for interrupt 0
	JMP	INT0	;
	ORG	100H	; defines where MAIN starts.
MAIN:
        MOV     SP,#60	; Move immediate data value 60 to location SP
	MOV	P1,#0FFH ;
	MOV	IE,#10000001B
	SETB	IT0	 ; negative edge trigger for interrupt 0
        CLR     EN	;clear EN
	CALL    LCMINIT
        CALL    WRINS
	JMP	$
INT0:
	CLR	EA
	CLR	C
	MOV	A,P1
	ANL	A,#0FH
	MOV	B,A
	SUBB	A,#10
	JC	NUMBER
	MOV	A,B
	ADD	A,#37H
	JMP	DISP
NUMBER:
	MOV	A,B
	ADD	A,#30H
DISP:
	CALL	WRDATA
	CALL	RDINS
	ANL	A,#01111111B
	MOV	B,A
	SUBB	A,#14H
	JNZ	TESTB
	MOV	A,#11000000B
	CALL	WRINS
TESTB:
	MOV	A,B
	SUBB	A,#54H
	JNZ	RETURN
	MOV	A,#10000000B
	CALL	WRINS
RETURN:
	SETB	EA
	RETI		; return from interrupt
WRINS:
        CALL    CHKBSY
        CLR     RS
        CLR     RW
        SETB    EN
        MOV     LCMBUS,A
        CLR     EN
        RET
RDINS:
	CALL	CHKBSY
	CLR	RS
	SETB	RW
	SETB	EN
	MOV	A,LCMBUS
	CLR	EN
	RET
WRDATA:
        CALL    CHKBSY
        SETB    RS
        CLR     RW
        SETB    EN
        MOV     LCMBUS,A
        CLR     EN
        RET
CHKBSY:
        MOV     LCMBUS,#0FFH
        CLR     RS
        SETB    RW
        SETB    EN
        MOV     C,LCMBUS.7
        CLR     EN
        JC      CHKBSY
        RET
LCMINIT:
        MOV     A,#00110000B
        CALL    WRINS
$1:
        MOV     R7,#50
        DJNZ    R7,$
        DJNZ    R6,$1
        MOV     A,#00110000B
        CALL    WRINS
        DJNZ    R7,$
        MOV     A,#00110000B
        CALL    WRINS
        CALL    WRINS
        CALL    WRINS
	CALL	WRINS
        CALL    WRINS
	MOV	A,#00001111B
	CALL	WRINS
        RET
PRTSTR:
        MOV     A,#0
        MOVC    A,@A+DPTR
        CJNE    A,#'$',PRINT
        JMP     ENDPRT
PRINT:
        CALL    WRDATA
        INC     DPTR
        JMP     PRTSTR
ENDPRT:
        RET
        END
