[SOLVED] Help with VHDL UP Counter
lamorak
Newbie level 3
Hello,
I am working on a project for class where our robot follows a line on the ground. when the inputs H&C = "00" the robot is supposed to increment its counter by 1 and display the number on the seven segment display. However my counter is not working and i dont have a clue how to make it work.
      process
        begin
          if (RST='0') then
            ABUS <= "0000";
          elsif (HC="00" and CLK='1') then
            ABUS <= ABUS + 1;
          end if;
      end process;
with ABUS select
SEG7   <= "11111110000001" WHEN B"0000",
              "11111111001111" WHEN B"0001",
              "11111110010010" WHEN B"0010",
This is the counter code i am using.
Any help would be greatly appreciated!
amitjagtap
Full Member level 5
you can try this process
process(clk,rst)
variable cnt: std_logic_vector(3 down to 0):="0000";
begin
if (rst='0') then
cnt <= "0000";
elsif (clk'event and clk='1') and (HC="00") then
cnt <= cnt + 1;
end if;
ABUS<=cnt;
end process;
& so on.....
Well ABUS assignment to 7seg was not clear how you are doing....
lamorak
Newbie level 3
amitjagtap,
thank you for your quick reply!
Good news and bad news,
Good news is it increments when HC = 00, however, it keeps implementing every CLK rising edge while HC = 00. I only want it to implement once per HC = 00.
Any way to make that work?
the abus to 7seg works, im just using a with select statement to get the proper number to display.
permute
Advanced Member level 3
you need some state information. eg:
if (clk'event and clk = '1') then
  if (HC = "00") then
    can_increment <= '0';
  else
    can_increment <= '1';
  end if;
  if can_increment = '1' and HC = "00" then
    cnt <= cnt + 1;
  end if;
end if;
the can_increment register will transition from 1 to 0 after HC=00. if HC becomes a different value, then can_increment will be 1 on the next cycle, which is the earliest the HC=00 condition could come along.
lamorak
Newbie level 3
thanks for the reply. I tried that, but now my counter does not increment at all. it just stays the same
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity lab5 is
port(
	RST, CLK, GO : IN std_logic;
	HC   : IN std_logic_vector(1 downto 0);
	ABIJ : OUT std_logic_vector(3 downto 0);
	SEG7 : OUT std_logic_vector(13 downto 0)
end entity lab5;
architecture behavioral of lab5 is
	type states is (S0, S1, S2, S3, S4, S5, S6, S7);
	signal D, Q : states;
signal ABUS : std_logic_vector(3 downto 0);
signal can_increment : std_logic;
begin
	DFF: process(RST, CLK)
	begin
		if RST = '0' then Q <= S0;
		elsif rising_edge(CLK) then	Q <= D;
		end if;
	end process;
process(clk,rst)
	variable cnt: std_logic_vector(3 downto 0):="0000";
	begin
			if (HC = "00") then
			else
			end if;
				cnt := cnt + 1;
			end if;
		end if;
	end process;
	D <= S0 when Q = S0 and GO = '1' else
		 S1 when Q = S0 and GO = '0' else
		 S1 when Q = S1 and HC = "11" else
		 S5 when Q = S1 and HC = "10" else
		 S4 when Q = S1 and HC = "01" else
		 S2 when Q = S1 and HC = "00" else
		 S7 when Q = S2 else
		 S7 when Q = S3 else
		 S4 when Q = S4 and HC = "01" else
		 S1 when Q = S4 and HC = "11" else
		 S5 when Q = S4 and HC = "10" else
		 S5 when Q = S5 and HC = "10" else
		 S1 when Q = S5 and HC = "11" else
		 S4 when Q = S5 and HC = "01" else
		 S7 when Q = S6 else
		 S2 when Q = S7 and HC = "11" else
		 S3 when Q = S7 and HC = "01" else
		 S6 when Q = S7 and HC = "10" else
		 S5 when Q = S7 and HC = "10" else
		 S4 when Q = S7 and HC = "01" else
		 S0;
	with Q select
	ABIJ <= B"1111" when S1 | S2,
			B"0011" when S5 | S6,
			B"1100" when S3 | S4,
			B"0000" when others;
	WITH ABUS SELECT
		          "11111110000110" WHEN B"0011",
		          "11111111001100" WHEN B"0100",
		          "11111110100100" WHEN B"0101",
		          "11111110100000" WHEN B"0110",
		          "11111110001111" WHEN B"1110",
		          "11111110000000" WHEN B"1000",
		          "11111110001100" WHEN B"1001";
		          "11111111111111" WHEN others;
 end architecture behavioral;
here is my code
TrickyDicky
Advanced Member level 5
your cnt variable doesnt connect to anything, and so is removed when the design is synthesised. I think you meant to replace cnt with ABUS.
capitan
Newbie level 5
you need an fsm to keep track of when you have encountered hc="00".
when state=not_encountered
       if(HC="00") then
            increment<='1';
            next_state<=encountered;
       else
            increment<='0';
            next_state<=not_encountered;
       end if;
when state=encountered
        if(HC="00") then
            increment<='0';
       else
            increment<='0';
       end if;
or something like that.
Also note that the 7segment displays are usually time multiplexed so you need some kind of controller to drive it properly. Otherwise it will just show a faded 0000.
lamorak
Newbie level 3
That did it! got it to work, fixed that and added process and end process that chunk of code and it works now!
thanks for the help everyone!
