help with vhdl coding
ahyuanz
sg
how to i write for
4input (a,b,c,d) and merge into 1 output with 4bits with 'a' as the msb and 'd' as the lsb
i just compiled and it pass, but will it work?
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
entity MUX is
    Port (
              EN         : in  STD_LOGIC;
           A_IN      : in  STD_LOGIC;
           B_IN      : in  STD_LOGIC;
           C_IN      : in  STD_LOGIC;
           D_IN  : in  STD_LOGIC;
              RES        : in    STD_LOGIC;
           MUX_OUT : out  STD_LOGIC_VECTOR (3 downto 0));
end MUX;
architecture Behavioral of MUX is
signal INPUT_PROCESS : std_logic_vector(3 downto 0);
begin
process (EN, RES)
begin
   if RES ='0' then
      INPUT_PROCESS <= (others => '0');
   elsif EN ='1' then
        INPUT_PROCESS(0) <= D_IN;
        INPUT_PROCESS(1) <= C_IN;
        INPUT_PROCESS(2) <= B_IN;
        INPUT_PROCESS(3) <= A_IN;
   end if;
end process;
MUX_OUT <= INPUT_PROCESS;
end Behavioral;
... or you could replace your process with
MUX_OUT <= (others => '0') when RES = '0' else A_In & B_In & C_In & D_In;
Your process doesn't specifiy what should occur when EN = '0', so I've omitted that too...
