tabascorez
Junior Member level 2
- Joined
- Nov 11, 2013
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 163
Hello
Can somebody help me with the vhdl code in the attachment. When I elaborate it on design vision, I get the error below. Does anyone know why so and can help out? Thanks
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 library ieee; use ieee.std_logic_1164.all; entity mult is generic ( N : natural :=56 ); port ( a_in : in std_logic_vector(N-1 downto 0); b_in : in std_logic_vector(N-1 downto 0); y : out std_logic_vector(2*N-1 downto 0) ); end mult; architecture structural of mult is type ab_type is array(N-1 downto 0) of std_logic_vector(N-1 downto 0); type c_type is array(N-1 downto 0) of std_logic_vector(N downto 1); type s_type is array(N-1 downto 0) of std_logic_vector(N-1 downto 0); -- signal ab : ab_type; signal c : c_type; signal s : s_type; signal d : std_logic_vector(N+1 downto 1); signal an : std_logic; signal bn : std_logic; signal sNm1Nm1 : std_logic; -- component fa port( ain : in std_logic; bin : in std_logic; cin : in std_logic; sout : out std_logic; cout : out std_logic ); end component; begin -- bit product gen_ab_i: for i in 0 to N-1 generate gen_ab_j: for j in 0 to N-1 generate g_abn_leftcol: if (i = N-1) and (j /= N-1) generate ab(i)(j) <= a_in(i) and not (b_in(j)); end generate g_abn_leftcol; g_anb_btmrow: if (i /= N-1) and (j = N-1) generate ab(i)(j) <= not(a_in(i)) and b_in(j); end generate g_anb_btmrow; g_ab_btmleft: if (i = N-1) and (j = N-1) generate ab(i)(j) <= a_in(i) and b_in(j); end generate g_ab_btmleft; g_ab_middle: if (i /= N-1) and (j /= N-1) generate ab(i)(j) <= a_in(i) and b_in(j); end generate g_ab_middle; end generate gen_ab_j; end generate gen_ab_i; -- top row gen_c_top_row: for i in 0 to N-2 generate c(i)(1) <= '0'; end generate gen_c_top_row; gen_s_top_row: for i in 0 to N-1 generate s(i)(0) <= ab(i)(0); end generate gen_s_top_row; -- leftmost column gen_s_left_col: for j in 1 to N-1 generate s(N-1)(j) <= ab(N-1)(j); end generate gen_s_left_col; -- full-adder matrix gen_fa_i: for i in 0 to N-2 generate gen_fa_j: for j in 1 to N-1 generate u_fa : fa port map ( ain => s(i+1)(j-1), bin => ab(i)(j), cin => c(i)(j), sout => s(i)(j), cout => c(i)(j+1) ); end generate gen_fa_j; end generate gen_fa_i; -- special (N-1,N-1) fa an <= not(a_in(N-1)); bn <= not(b_in(N-1)); u_fa_nm1sq : fa port map ( ain => an, bin => ab(N-1)(N-1), cin => bn, sout => sNm1Nm1, cout => c(N-1)(N) ); -- final stage adder gen_fsa: for i in 0 to N generate gen_fsa_0: if i = 0 generate u_fa_fsa_0 : fa port map ( ain => s(i)(N-1), bin => b_in(N-1), cin => a_in(N-1), sout => y(i+N-1), cout => d(1) ); end generate gen_fsa_0; gen_fsa_mid: if i > 0 and i < N-1 generate u_fa_fsa_mid : fa port map ( ain => s(i)(N-1), bin => d(i), cin => c(i-1)(N), sout => y(i+N-1), cout => d(i+1) ); end generate gen_fsa_mid; gen_fsa_n : if i = N-1 generate u_fa_fsa_n : fa port map ( ain => sNm1Nm1, bin => d(i), cin => c(i-1)(N), sout => y(i+N-1), cout => d(i+1) ); end generate gen_fsa_n; gen_fsa_np1 : if i = N generate u_fa_fsa_np1 : fa port map ( ain => '1', bin => d(i), cin => c(i-1)(N), sout => y(i+N-1), cout => d(i+1) ); end generate gen_fsa_np1; end generate gen_fsa; -- bottom row and output (lower half) gen_out: for j in 0 to N-2 generate y(j) <= s(0)(j); end generate gen_out; end structural;
