Help with vhdl code for a counter
Jetach
Member level 1
Member level 1
Hello guys, I am writing vhdl code for a two timers which count in gray code. Counting up on the rising edge and the other counting up on the falling edge.
When I run a test bench of the code, it counts up correctly, but it will skip clock cycles and a weird pattern.
Here is the code and test bench results.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity cntcore is
    Port ( enable : in  STD_LOGIC;
           reset : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           out1 : out  STD_LOGIC_VECTOR (7 downto 0);
           out2 : out  STD_LOGIC_VECTOR (7 downto 0));
end cntcore;
architecture Behavioral of cntcore is
signal count1 : std_logic_vector (7 downto 0);
signal count2 : std_logic_vector (7 downto 0);
begin
process(clk, reset, enable)
begin
    if reset = '1' then
        count1 <= "00000000";
        count2 <= "00000000";
    end if;
    if rising_edge(clk) then
        if reset = '0' and enable = '1' then
            count1 <= count1 + 1;
            out1(7) <= count1(7);
            out1(6) <= count1(7) or count1(6);
            out1(5) <= count1(6) or count1(5);
            out1(4) <= count1(5) or count1(4);
            out1(3) <= count1(4) or count1(3);
            out1(2) <= count1(3) or count1(2);
            out1(1) <= count1(2) or count1(1);
            out1(0) <= count1(1) or count1(0);
        end if;
    end if;
    if falling_edge(clk) then
        count2 <= count2 + 1;
        out2 <= (count2(7), count2(7) or count2(6), count2(6) or count2(5),
                    count2(5) or count2(4), count2(4) or count2(3), count2(3) or count2(2),
                    count2(2) or count2(1), count2(1) or count2(0));
        end if;
    end if;
end process;
end Behavioral;
Any help on why the counter is not following the clock cycles would be awesome.
XOR, not OR?
Ha. Perfect that fixed it immediately thank you. I had to rewrite code in vhdl from verilog and for some reason thought ^ was OR.
Thanks for saving me a crapload of time.
library IEEE;
library UNISIM;
entity cntcore is
           clk : in  STD_LOGIC;
end cntcore;
begin
begin
	if reset = '1' then
	end if;
		end if;
	end if;
		end if;
	end if;
end process;
end Behavioral;
--process(clk, reset, enable)
if reset and enable are sync then only clk is in sensitivity process(clk) list also :
if reset is async then
process(clk, reset) and :
--if reset = '1'
--end if;
if reset = '1' ...
elsif rising_edge(clk)
end if;
and :
--if reset = '0' and enable = '1' then =>
if enable = '1' then
