help with using RS encoder in Simulink
haneet
Full Member level 3
hi guyz..
i am trying to run a block diagram on simulink and in that i need to use this RS encoder which i could pick but then i get som eerror which states:
Error reported by S-function 'scominttobit' in 'untitled/Binary-Input RS Encoder/Bit to Integer Converter':
In case of frame-based inputs, the input must be a column vector whose width is an integer multiple of the number of bits per integer.
you can find the block diagram in the attachement
thanks,
Haneet
