Help with TMS320C54X TI processor
catilo
Newbie level 3
HI, I´ve a TMS320C54X DSK board from TI and an emulator from Spectrum Digital, but I can´t find some example programs in C or assembler for this processor and using Code Composer Studio. Have someone some information about it.
Thanks.
the_jackal
Member level 4
If you purchased the DSP processor from TI then i believe it should come with some sample programs implemented using code composer studio.
catilo
Newbie level 3
Yes but this TMS32C542 DSK doesn't come with sample programs in CCS, just in an older program called Code Explorer 54x.
Circuit_seller
Full Member level 5
Hi
Try this book:
"eal-time Digital Signal Processing Implementations, Applications and Experiments with the TMS320C55x"
this book include some example codes, it is available in emule, MCU, ...
Regards
    catilo
gooodman
Member level 2
There are the book and codes.
    catilo
gooodman
Member level 2
and This is the website of this book
j2005
Member level 2
Watch out for the sample programs from TI. Some of them are buggy. I won't trust them too much. Also, code explorer 54x only works with assembly language. You'll need to get a C compiler if you want to write in C. TI usually charges you for one of those. However, you may be able to get one for free that's compatible with the TI processor.
If you think this has helped, please click "helped". Thanks.
    catilo
