I was required to interface a max6675 temp. sensor with a spartan 3e fpga board using vhdl. The temp was supposed to be displayed on a extension board with a 7 bit display. i have managed to get everything working but i have one small problem that i can't seem to solve. curently in order to read the temp, i have to to select the reset button to do it. when i release the reset button, it reads the current temp and shows it on the display but i need it to run in real time. I have tried for hour but still can seem to figure out what is the problem so i was hoping some of the pros here can help me figure out what is wrong. thanks. i have attached a word doc containing the codes that i used.
