mvaldezrubio
So I am going to buy a havahart in ground fence for pets. I want to see if i can make the radio signal travel in a 2D plane. I was thinking of using foil to block off the directions that I do not want the wave to travel. Hopefully, this will make a "wall" so that if the receiver intercepts the "wall" the device will go off. Is this possible? Any help will be appreciated. Thank you.
