Help with PLC 214,(Subroutines,tables and memory)
KRAIG
Member level 1
how to use subroutines in s7 software
I made a program in ladder diagram which turns on an output for 3secs.Then it turns it off and turns on another output for 5 secs.It does this 4 times.
I want to do the same in a subroutine.
As i understood from the help of Mirco/Win i have to make a table and to fill memory with the data i want.
Problem is i didnt understand anything else.
Can someone tell me 2 things to understand how i can do it with a subroutine that is called again and again and does it with variables that change the output and the duration.
Also if you have any links i could study
Thank you in advance
subroutine micro win
is the plc Siemens s7 214 ?
s7 212 manual
Yes this is the plc(s7 214).
subroutine plc ladder
do you know how a plc works?
do you have the manual of the s7 214 ?
plc subroutine
i have studied the only source of information i have and that is the help file of micro win v4.0.1.I know a lot about mcu programming,however.
We dont have any books in my school,nor the manual.That is the reason why i ask for some links.
Anyway today i was able to do something.
I made a subroutine.When i close the I0.0 switch it enters the sub.
sub:
net 1:
( in ladder):
move the address of Vb0 to (pointer) Ac1 (MOV_DW,&VB)->AC1)
net 2:
add to the ac1 the number 2,so as to go to the next variable. Then de-reference the pointer and i use it as a value to a timer.(T32,PT= *AC1)
So by using these variables and setting tha data block like this:
vb0 0000
vb2 2000
vb4 1000
I think that my subroutine is able to pass different value(tha ones in the datablock) to the timer.
am i wrong somewhere?
I also used the same method to have different ouputs for every time.
s7 ac1 +i
sub:
net 1:
( in ladder):
net 2:
vb0 0000
vb2 2000
vb4 1000
i used the plc s7 212 once to program some runing lights but i didn't use subroutines just blocks and they keep reccuring, and a few timers. i bet the plc s7 214 is not that different from it.
i am not really getting what you really want to do with the sub routine ?
what are you using the plc for ?
plc subroutin
I want to turn on Q0.0 for 3 secs,then turn it off and turn on for 5secs Q0.1 then turn Q0.1 off and turn on Q0.2 for 7 secs.
plc subroutines
definitley you need more than 2 networks
simplest way is
---|T1|---|/T2|---|/T3|---(q0.0)
---|/T1|---|T2|---|/T3|---(q0.1)
---|/T1|---|/T2|---|T3|---(q0.2)
this is the logic now you need to implement it, i dont have the s7 software sry :|.
Do you know how timers work ?
