qpasatio
Newbie level 5
I’m trying to simulate in Proteus 6SP4 one hi-tech PICC18 8.3 Program without any result. The Program resets each 2 or 3 seconds. I suppose that the problem is the WDT. When I activate it ,the WDT resets the program and when I deactivate it, the micro doesn’t start the program.
I have tried to configure the micro with __config() and with the chip options in proteus, without any result for days.
Maybe the problem is the compiler (I use the demo program), any bug in the Proteus 6sp4, or the MPLAB 6.3?
Any suggest? Does any of you have the same problem?
I don’t know what to do. I have studied the samples of proteus (calculator and chess) and I don’t see any special thing related to the fuses or something similar.
Thanks
Thanks
