Help with Pic 18F2550
Matheus_Carvalho
Newbie level 6
I'm trying for a long time to find a simple code example for using the USB output of the pic, in my project I just need to send a signal from pic to USB port of a computer. I'll use Labview to interpret this signal. My problem is that so far I don't find any tutorial that could help me. Another thing, I 'll use Mplab C18. Anyone have any tutorial or book that could help me?
wp100
Advanced Member level 5
Prime Meridian
Simple code for USB - I wish !!
If you go to Microchips site they have a massive section of free working examples for C18, just find them from the main menu.
If thats over the top for you current need, then the simple way is to use the USART serial comms and use a printer cable / serial to USB converer - which are around quite cheaply at the right place.
daviddlc
Full Member level 5
USA
Read the book USB Complete by Jan Axelson.
Also check this site:
http://www.lvr.com/index.html
I have that type of code, but you will learn way more if you do it by yourself.
Matheus_Carvalho
Newbie level 6
I can't afford a book like this, and I'm very new at this topic, if you send a code example I would be very grateful and I'll study it to learn.
DNS28
You can find examples in mikroC compiler using PIC USART modules. Personaly I prefer C18 compiler which has also good libraries to use the USART modules. It is much easier to use the serial port then convert it to USB than config the USB interface directly in the PIC.
gimminleonhart
Newbie level 2
hi,my project also need to send signal from pic2550 to PC via USB.
but is it possible by using the C language, preferebly written using CCS C compiler.
Can someone point me to right direction?
Is that any sample coding provided online?
hameeds01
Advanced Member level 2
Islamabad Pakistan
https://www.youtube.com/watch?v=1eaeWfA4P5E
anandpv2009
Advanced Member level 1
Search example folder of CCS compiler root. say "C:\Program Files\PICC\Examples".
Eg.
ex_usb_serial.c
ex_usb_hid.c
etc.
I recommend you to use C18 bcoz its more comfortable for me and good samples and technical support,library etc are available.
Good luck.
