ups problem
Hi.
I try to desing a UPS with UPQC topology for non-lineal load, genering a signal with dsPIC30F4011 with modulation PWM in 40kHz, but i have a big problem with noise in output signal in my inverter mosfet when I connect my low pass filter.
My low pass filter is in output of my mosfet full bridge, to make a signal in 50 Hz, as show in this schematic. [/img]
The voltaje output is a 330 Volts, peak (or 220 Volt RMS)
Please help me if exist some error in my circuit or is missing something.
Very thank
