aishiqi
Newbie level 1
i want 10 bit precision of ADC with my code below.but the problem is that the result does not change Continuously while i change the voltage continuously with two Precision potentiometer.
do you konw what i mean??
for example :
now ADCL is 0x56.i turn the potentiometer slowly, but ADCL doesn't change immediately .i keep turning, suddenly ADCL changes to 0x60,then 0x62,then0x63,then0x71;it can't be 0x57,0x58,0x59,0x61...........
i hope someone can help me!! thanks a lot first .
this is my code:
#include<iom16v.h>
unsigned long angular,adth,adtl;
unsigned char count=0,adjok=0;
unsigned long speed=0;
unsigned long temp;
adinit()
ADMUX=0xc0;
ACSR=0x80;
ADCSRA=0xc8;
uinit()
UBRRL=51;
UCSRB|=0x88;
SREG|=0x80;
portinit()
DDRA=0;
PORTA=0x00;
delay(){
unsigned int i;
for(i=0;i<100;i++);
sendchar(char ch)
while(!(UCSRA&0x20));
UDR=ch;}
adjust()
{SREG&=0x7f;
speed=0;
angular=0;
count=0;
adjok=0;
SREG|=0x80;
#pragma interrupt_handler adcsvr:15
adcsvr()
adtl=ADCL;
adth=ADCH;
ADCSRA=0xc8;
//sendchar(adth);
sendchar(adtl);
angular=angular+((adth<<8)+adtl)*1000-speed;
if(adjok==0)
if(count<255) count++;
else
{adjok=1;
speed=angular/256;
main()
MCUCR=0x00;
uinit();
portinit();
adinit();
delay();
adjust();
while(1)
/*sendchar(adtl);
sendchar(angular>>24);
sendchar((angular>>16)&0xff);
sendchar((speed>>8)&0xff);
sendchar(speed&0xff);
delay();
for example :
this is my code:
#include<iom16v.h>
unsigned long temp;
adinit()
ADMUX=0xc0;
ACSR=0x80;
ADCSRA=0xc8;
uinit()
UBRRL=51;
UCSRB|=0x88;
SREG|=0x80;
portinit()
DDRA=0;
PORTA=0x00;
delay(){
unsigned int i;
for(i=0;i<100;i++);
sendchar(char ch)
UDR=ch;}
adjust()
{SREG&=0x7f;
speed=0;
angular=0;
count=0;
adjok=0;
SREG|=0x80;
adcsvr()
adtl=ADCL;
adth=ADCH;
ADCSRA=0xc8;
//sendchar(adth);
sendchar(adtl);
if(adjok==0)
else
{adjok=1;
speed=angular/256;
main()
MCUCR=0x00;
uinit();
portinit();
adinit();
delay();
adjust();
while(1)
/*sendchar(adtl);
delay();
